#84141
There is an option in the plugin where I can set mediaElement to load only by Component or Menu. What is the format for the component? Something like:
com_content,com_zoo,com_banner...
Is that how the entry should be? Separated by comma?
Wouldn't it be easier if the option is multi select of components instead of typing the name? Or maybe put the component that I donot want MediaElement to load instead of the current default.
Thanks!
Jackson
Thanks!
Jackson
