- Popup Issue after upgrade to Pro
Because of the string at the end of the image URL, ie: ?5852814a, Mediabox is not treating the image as an image, but as an HTML URL and is opening it in an iframe. The width of the popup is therefore not determined by the image dimensions.
Add type="image/jpeg" to the popup link, or select "Image" as the Media Type when creating the popup.
I uploaded images as usual and inserted them with popup feature enabled as in all other pages. You can check it using the login data I sent you for the other thread (https://www.joomlacontenteditor.net/support/forum/what-is-style-background-color-initial)
Something on your site is adding a string to the end of the image as I said in my previous post, which is causing MediaBox to treat the popup link as an HTML page and load it in an iframe.
To overcome this you must set the Media Type to Image when you are creating the popup, or disable the process that is adding the string to the URL.
Anyway, as you can see here: http://www.squilibri.it/catalogo/crinali/la-macina-nel-vivo-di-una-lunga-storia.html
in other pages it works fine. I don't know
If you compare the URL of that popup, which is working
to the one that is not
you can see the string added to the end of the second URL.
This is being done when the page loads, not by JCE MediaBox, and not when the content is created or updated.
It seems an issue about Gantry, assigning a default template the popup works fine:
http://www.squilibri.it/f-a-q/test.html
the strange thing is that old articles haven't problems.
Please upgrade to JCE MediaBox 1.2.4 - https://www.joomlacontenteditor.net/downloads/mediabox/category/joomla-3
Please try again - https://www.joomlacontenteditor.net/downloads/mediabox/category/joomla-3
I named the file with the wrong version number and had to upload them again.
