- Prevent Managers or other users from Deleting images
Hi Ryan
Is there a way to prevent a backend user, such as a Manager, from deleting or even seeing images within a folder?
I'm looking for a way to prevent users from deleting certain images. I was thinking if I put those images within a folder, then that would be the easiest way to prevent them.
Thoughts?
Thoughts?
You can't place restrictions on specific images in a folder, but you can restrict an editor profile (assigned to a specific user or usergroup) to a folder, by adding variables to the File Directory Path - https://www.joomlacontenteditor.net/support/tutorials/editor/item/setting-the-file-directory-path
