- Problem with uploading ..
Hello, I'm having problems uploading. I have looked into Media Manager aan JCE File browser. I am getting various error messages. I have tried adding into the 'permitted file types' (I've looked in so many places I forget where that was!) but still no joy. I know I've added pdf before,; not sure about tif. I've checked regarding spaces in the titles.
Any ideas where my problems may lie?
Robin
Robin
What error messages are you getting when attempting to upload with:
a) The Joomla Media Manager?
b) The JCE File Browser?
Does this happen with all files, or just ones of a specific type?
#83676
Hello Ryan,
here I am trying to upload via File Explorer;
http://screencast.com/t/lTgKGPCg6
Here is the error message;
http://screencast.com/t/lC6ry70D
Here's another which says that a file exceeds max file size:
http://screencast.com/t/upMN4flCmBt
(I can't see where to control this)
Via Media Manager:
http://screencast.com/t/NFIhWt1fxUq
two files apparently upload but are not detected: http://screencast.com/t/4q1kd72ywf
Another says' not a valid image: http://screencast.com/t/hhEhT0o15Zf1
Help!!
Cheers, Robin
Via Media Manager:
Help!!
Cheers, Robin
You need to add tif as a valid extension to the Image group.
https://www.joomlacontenteditor.net/support/tutorials/editor/item/permitted-file-extensions
https://www.joomlacontenteditor.net/support/tutorials/editor/item/setting-the-upload-file-size
Via Media Manager:
I can't comment on the Joomla Media Manager errors, as those don't have anything to do with JCE, but the extension type might be an issue here (tif instead of tiff)?
#83678
Hi Ryan, yes I found this instruction yesterday, But! i can't actually find where the control panel is. Sorry. Please tell me the idiot's guide to finding it.
Cheers, Robin
Cheers, Robin
#83679
Found it! Slightly different layout in J3, I think.
I've uploaded the tif and large pdf ok now, thanks. However, the tif image doesn't display, is there another parameter somewhere to allow a tif image to actually display? At the moment it seems to embed as an icon.
#83682
So:
I've enabled tif: http://screencast.com/t/od8w5LpD
but get this: http://screencast.com/t/3YzY5KhuKlh
...? Robin
...? Robin
Can you see the file if you link to it directly?
Does this happen with all images, or just this one tiff file?
#83689
No: If I create the link below:http://www.sightlines-initiative.com/images/Library/conferences/March_2016_Networks/our_changes.tif
it prompts a 'save as' window.
However, a direct link to a different file in the same folder opens fine:
http://www.sightlines-initiative.com/images/Library/conferences/March_2016_Networks/our_changes_sightlines_march2015.pdf
It seems to happen only with tif file extension (I wanted to use tif file because it seemed to provide better quality) . but maybe it is a bad idea?
I personally think embedding of tif files in a webpage is suboptimal because not all webbrowser will support it.
https://en.wikipedia.org/wiki/Comparison_of_web_browsers#Image_format_support
Your server does not support this file type as an image file.
Add this to the top of your .htaccess file:
AddType image/tiff .tiff .tif
#83693
Thanks Ryan,
I will do this. I think I'll need to re-install AdminTools Pro.
Cheers, Robin
Cheers, Robin
