#115973 MediaBox popup not working
Latest post by Dario22 on Friday, 26 January 2024 14:24 GMT
Dario22
Dear Sir/Madam, I don't know exactly when the problem started to occur, but I've just found out that the MediaBox popup component doesn't work anymore.
If I click on the image nothing happens, and the problem occurs with the new and the previously created images+popup.
I've installed all the updates of JCE and I also have the latest version of MediaBox.
As far as I remember I haven't changed any options in the profile or global configuration.
I'll provide a couple of example:
Bottom of the page (footer), the QR Code should popup the 100% size when clicking:
Go to the bottom of the page, the popup image is the QR Code of the site.https://www.iisbassanoromano.it/
A previously created article in which there is an image that should popup the original image in full size:
Tornei sportivi scuola
Thanks for your answer in advance.
Dario Brama
You have a javascript error on the site:
https://cdn.joomlacontenteditor.net/tmp/115973-mediabox-popup-not-working-1.jpg
which may be blocking other scripts, like MediaBox, from executing.
Dario22
The only thing I can think of is a new plugin which interferes with all "popups" scripts.
Can JQuery in a plugin (enabled or disabled) be the cause?
[quotePost id="115985"]The only thing I can think of is a new plugin which interferes with all "popups" scripts.
Can JQuery in a plugin (enabled or disabled) be the cause? [/quotePost]
No there appears to be a missing function "autocomplete" which has not been loaded. Whatever is attempting to execute this function has not loaded the required scripts.
Dario22
I know it may sound stupid but I reinstalled my template (Joomlart JA Coach + T4 System plugin) and everything's working now. Thanks for your help and explanation.
