When someone adds a support ticket there is a TEXT field and JCE Eitor Pro will not all the user to enter data
You need to create an editor profile that allows registered users to use the editor, ideally only within the context of RSTickets Pro, and limiting the functions of the editor.
1. Go to Components -> JCE Editor -> Profiles
2. Check the Front-End profile, and click the Copy button.
3. Click on the new profile create (Copy of Front End) to edit it.
4. Give the profile a
Title and
Description, set the
Status to
Published, and set the
Ordering to
First
5. For
Components, check
Select from list, and then click in the field to find and select
RS Tickets Pro
6. Select
Registered in the
User Groups field (and any other groups you would like to use this profile)
7. IMPORTANT - Click on the Features & Layout tab, and add or remove any buttons you do or do not want the user to have access to.
8. Click Save.
When submitting a ticket in the front-end, the user should now see the editor you have configured in the profile.
