- pasting text into jce doesn't work
dear jce-team,
i used jce for years and many projects, right now i have an issue with only 1 project, where i can't paste text into the editor.
if i do, following error comes into the console:
core.js?db5ab3955268ef4da73f17aafd446ca9:1
window.writeDynaList() is deprecated without a replacement!
window.writeDynaList @ core.js?db5ab3955268ef4da73f17aafd446ca9:1
tiny_mce.js?3e9633d70f3923f7697cc29fad1f8d7d:11
Uncaught Error: Syntax error, unrecognized expression: code,
at Function.Sizzle.error (tiny_mce.js?3e9633d70f3923f7697cc29fad1f8d7d:11)
at Sizzle.tokenize (tiny_mce.js?3e9633d70f3923f7697cc29fad1f8d7d:11)
at Object.Sizzle (tiny_mce.js?3e9633d70f3923f7697cc29fad1f8d7d:10)
at DOMUtils.select (tiny_mce.js?3e9633d70f3923f7697cc29fad1f8d7d:10)
at postProcess (editor_plugin.js?a4d17e1b09f2c662075301847c267c2d=1&context=16&3e9633d70f3923f7697cc29fad1f8d7d:2)
at p.<computed>.p.<computed>.<anonymous> (editor_plugin.js?a4d17e1b09f2c662075301847c267c2d=1&context=16&3e9633d70f3923f7697cc29fad1f8d7d:3)
at Dispatcher.dispatch (tiny_mce.js?3e9633d70f3923f7697cc29fad1f8d7d:7)
at pasteHtml (editor_plugin.js?a4d17e1b09f2c662075301847c267c2d=1&context=16&3e9633d70f3923f7697cc29fad1f8d7d:3)
at insertClipboardContent (editor_plugin.js?a4d17e1b09f2c662075301847c267c2d=1&context=16&3e9633d70f3923f7697cc29fad1f8d7d:3)
at Editor.<anonymous> (editor_plugin.js?a4d17e1b09f2c662075301847c267c2d=1&context=16&3e9633d70f3923f7697cc29fad1f8d7d:3)
DevTools failed to load SourceMap: Could not load content for chrome-extension://hdokiejnpimakedhajhdlcegeplioahd/sourcemaps/onloadwff.js.map: HTTP error: status code 404, net::ERR_UNKNOWN_URL_SCHEME
pasting text works with tinymce
looking forward for feedback,
best,
bart
best,
bart
Please try JCE Pro 2.8.15 Beta 1 - https://www.joomlacontenteditor.net/downloads/editor/pro/development
