  Thursday, 06 May 2021
  7.4K Visits
Inserting columns with dialog box don’t seem to work — Clicking button “insert” do nothing?
Doing it by the graphical representation work
#107790
Same error on Firefox Dev edition
This was tested successfully in Firefox Dev, so it must be a browser cache issue on your side.
#107760
It's working fine in my tests and on the demo site - https://demo.joomlacontenteditor.net/
If the dialog is unresponsive, it could indicate a javascript error. What is being displayed in the browser Javascript Console?
#107764
#107775
I don’t even remember if I send you the login, I will send it after this post. ......... Hyper busy .....
I reset the temporary user on my test site and test it to see if you can go in — It work
On Firefox Dev console, when I click the insert button I got an error at each click, always the same...
Uncaught DOMException: String contains an invalid character on tiny_mce.js:10
Here 2 clicks:
#107787
#107789
JCE Pro 2.9.7 RC
Work perfectly on Chrome
#107790
#107791
Cool SOLVED
Chacapamac selected the reply #107790 as the answer for this post — 7 months ago
