  Friday, 01 October 2021
  609 Visits
Hi
I am experiencing difficulties installing JCE MediaBox - upgrade to 2.1.2
I have tried from the Joomla update and also downloaded the file etc
The message received is
Warning
JFolder: :delete: Path is not a folder. Path: /home3/asw1f7sc/public_html/pscv3/plugins/system/jcemediabox/addons
JFolder: :delete: Path is not a folder. Path: /home3/asw1f7sc/public_html/pscv3/plugins/system/jcemediabox/elements
Joomla\Filesystem\File::delete: Failed deleting index.html
and then
Error
Error installing plugin
I hope you can help
This is happening on more than one web site
Stephen
3 weeks ago
#108964
Are you attempting to uninstall the old version of MediaBox befere installing 2.1.2? MediaBox does not remove the folders you listed when it is installed.
3 weeks ago
#108965
Hi
No, I did not uninstall the old version - should I?
stephen
2 weeks ago
#108969
2 weeks ago
#108972
There appears to be a folder permissions issue with the existing (old) version of Mediabox you have installed.
Please use an FTP application to delete the plugins/system/jcemediabox folder, then install the new version of JCE MediaBox.
2 weeks ago
#108973
Hi Ryan
That fixed it - all ok now
Many thanks
Stephen
