  Wednesday, 06 July 2022
  354 Visits
since a update the Watermark Text field encodes Special Characters on save, but doent convert it back on output( Seems like charset or html_entity_decode or similar function is missing/wrong)
Specs:
Joomla 3.10.X
JCE Pro 2.9.27
How to reproduce the problem:
Go to JCE Editor Pro ->Profiles -> "Default profile" (Or any other) ->Editor parameters -> Filesystem
Scroll to Watermark -> Text (input)
Input any string like "René Descartes" or "Friedrich Dürrenmatt" and save the settings.
Go back to the input field and the string is outputted with Html Entites encoded. (before/after Screenshot added)
Is there a solution or setting how to fix/adjust this?
Thanks in advance,
Thorsten
#111393
#111393
darkside selected the reply #111393 as the answer for this post — 3 months ago
#111399
CE Pro 2.9.28 Beta 2 fixes the problem!
Thanks for your response,
Thorsten
