#112953 When bootstrap 5 with multi columns?
Latest post by stof on Wednesday, 01 February 2023 10:27 GMT
stof
I see I can choose UI Kit and Bootstrap 4 to create columns.
Do you know when 5 will be inlcuded? As I build with bootstrap 5 it would be nice when I only need to load one bootstrap version.
Thanks.
Columns supports Bootstrap 4 and 5.
stof
Ah okay I thought I could only choose 4?
https://www.screencast.com/t/OYMzC0Rv
So when bootstrap 5 is installed it uses 5?
Which JCE Pro version do you have installed? That option was updated a few versions ago to show Bootstrap 4/5
https://cdn.joomlacontenteditor.net/tmp/112953-when-bootstrap-5-with-multi-columns.jpg
The classes it uses are the same in both versions.
stof
Ai .. Yes that was it. I updated and now I see it.
Thanks!
