Edit: No change after installing JCE Pro 2.9.35 Beta 1. Had to return to 2.9.33.
Thanks Tom
A content editor for Joomla!®
Latest post by Agent-Smith on Wednesday, 22 March 2023 22:01 GMT
For example: I copy and paste a text, format it, insert links, if I press "save" from joomla, the text is completely deleted, and everything I pasted with control+c and control+v disappears.
I followed the same procedure on my mac, and in fact the problem repeated itself.
I have a staging area where I can try to reinstall the new version to replicate the problem in a video. Can it help you?
I cloned the whole website in a staging area and I redid the update of Joomla to version 4.2.9 and of the editor to the same version 2.9.34, to then install the 2.9.35 beta 2.
CTRL+V paste text but doesn't keep both line breaks (one for new line and one for empty line), example:
text
text
text
When paste doesn't keep empty line by creating empty DIV, Pad Empty Tags is set to YES.
Editor Global Configuration:
Div Container & Div on Enter
or
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
becomes:
<div>Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.</div>
<div>Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.</div>
Your post is being submitted…
