J4 4.3.0
JCE pro 2.9.36
Acymailing 5.11.6
I don't success with using Acymailing templates with JCE editor when creating a newsletter.
On acymailing site, it's said :
JCE editor styling issue
If you use the JCE editor and it doesn't display the styles you created in the template edition, then you should go in the global configuration in the JCE administration and change the parameter "Compress CSS" to No.
But it doesn't work. Has somebody a solution ?
J4 4.3.0
JCE pro 2.9.36
Acymailing 5.11.6
