  Wednesday, 24 May 2023
  165 Visits
GOAL: need 100M uploads regardless of source/purpose (installs, images etc)
1.added php.ini to root of site.
2.checked with phpinfo.ini. AOK
3.JCE still says max is 2048kb under profiles.
4.Joomla set to 100M in media manager.
5.Can't upload large files.
QUESTION: What am I missing?
NON_PERMANENT WORKAROUND: uploaded unzipped files to /tmp (in this case, upgrading to JCE PRO from JCE, which is over 2048 and won't let me install) and installed that way.
one week ago
#113817
You should be able to set the Upload File Size value to whatever you want. The "Your server's maximum upload size" label is just a label, not a restriction.
one week ago
#113815
You need to set the upload_max_size and post_max_size php configuration values to the same value. upload_max_size must be equal to or less than post_max_size.
one week ago
#113816
both upload_max and post_max are now set to 64M and problem still persists within JCE profile settings. Still 2M limit.
one week ago
#113817
one week ago
#113818
I agree. JCE won't let me enter anything above the 2048 limit.
one week ago
#113819
Scratch that, it stuck. Thank you for your assistance. VERY much appreciated.
pxlsmatter selected the reply #113817 as the answer for this post — 1 week ago
