#99277 Issues with popups after upgrade to 2.7.7
Latest post by ctx2011 on Saturday, 08 February 2020 12:42 GMT
ctx2011
I am not sure which category to put this problem, because it would fit to more - the issue came with the editor upgrade and impacts JCE Mediabox and the Widgetkit2 Lightbox plugin.
Since the upgrade,
- JCE Media Box does not get the Group parameter from the component's Profiles setting.
- Widgetkit2 lightbox is not listed on the Profiles - default - Plugins - Image Manager Extended page in the Popups section so there are no configuration option for that.
(I use the latest version of all plugins, latest Joomla! version 3.9.5 with PHP 7.1.28, Yootheme Pro template 1.19.2).
It is strange but Widgetkit2 lightbox do get the group parameter right.
Any hint?
Krisztina
Please install JCE Pro 2.7.8 - https://www.joomlacontenteditor.net/downloads/editor/pro/latest
I will be releasing an update for the WidgetKit 2 plugin soon.
ctx2011
Thanks Ryan, but I see no change 🙁
On the Popups tab of Image Manager Extended the Group field still does not get the setting from the component settings (Profiles - Default - Plugin Parameters - Image Manager Extended tab, Popups section - JCE MediaBox Popups Group setting). Strange is that if I choose Widgetkit2 Lightbox from the Popups dropdown it does get the parameter set for JCE MediaBox (which is great).
Krisztina
Please upgrade to JCE Pro 2.7.9 - https://www.joomlacontenteditor.net/downloads/editor/pro/latest
ctx2011
Hi Ryan, I also have this issue with Widgetkit2 Lightbox in JCE 2.8.5 - no settings for Widgetkit2 Lightbox (although I can choose it as the default popup). and it forgot the JCE Mediabox Group parameter too 🙁 (When I change the popup type in the article it disappears).
Please try WidgetKit 2 Popups 2.0.2 - https://www.joomlacontenteditor.net/downloads/plugins/widgetkit2-popups
ctx2011
Thanks Ryan, the only change I see is an Enable/Disable option for Widgetkit2 Lighbox. It still does not get the Group setting from JCE Mediabox and there is no way to set a default. Does it work for you? Maybe I am missing something. Default editor is JCE Pro, template Yootheme Pro, Widgetkit 2 is installed.
This is working for me. When a set a value for the Group option in the MediaBox parameters in Editor Profiles -> Plugin Parameters -> Image Manager Extended, then I do see the field set with this value in the Popups tab of the Image Manager Extended dialog when the Popups option is set to JCE MediaBox.
https://cdn.joomlacontenteditor.net/tmp/99277-issues-with-popups-after-upgrade-to-2-7-7.jpg
ctx2011
With JCE MediaBox Popups it works for me too, when I switch to Widgetkit2 Lightbox it does not pick it from the Mediabox settings - earlier that worked too. Could you please check with Widgetkit2 Lightbox?
