I was contacted by a client that the popups changed. I solved some of this like showing the magnifying glass, that's a setting.
But now the transition is not like the images slide, but disappear and than come back. The client think that's to restless. But I see no option to change that. Is it possible the old way. You can see how it is now here: https://bluetrout.nl/work/128-shimmer and click on one of the small images.
Also if I change the background I can't change the color of the text. Do I have to do that in my stylesheet? Would be nice if that was just a setting.
I use JCE pro and mediabox on J3 in this case. The only settings I have are (see image):
Travel the world with me !
We you perhaps using MediaBox 1.2 on the site? The transitions changed in MediaBox 2. There isn't an option to change them.
Yes you would need to change this in the stylesheet, eg:
.wf-mediabox-theme-shadow .wf-mediabox-caption h4, .
wf-mediabox-theme-shadow .wf-mediabox-caption p,
.wf-mediabox-theme-shadow .wf-mediabox-numbers button {
color: #333;
.wf-mediabox-theme-shadow .wf-mediabox-next > svg,
.wf-mediabox-theme-shadow .wf-mediabox-prev > svg {
fill: #333;
color: #333;
fill: #333;
Thanks Ryan,
The css I understand but you can change the backgroundcolor so for users who don't understand it would be maybe a nice idea to give them the option to change text color as well.
You had a typo in the code so I place it here again.
The transition that can't be changed is a bummer. It's very nervous for a lot of readers. Any change in the future (sliding only) would be very welcome.
Anyway, thanks again for the fast response.
.wf-mediabox-theme-shadow .wf-mediabox-caption p,
color: #333;
fill: #333;
