  Wednesday, 17 May 2023
  180 Visits
Hi guys,
when I allow WYSIWYG editor in RSform PRO text area fields - the fields can't be accessed and JCE editor doesn't load.
(RSjoomla tells me to contact you, since TINY mce DOES work.)
kr.
John
2 weeks ago
#113790
The editor is displaying in the front-end in my tests.
In the Editor Profiles list, the "Front-end" editor was second in the list, with the "Default" profile above it, which was also configured to load in the front-end, so this was being selected instead of the "Front-end" profile.
I re-ordered the profiles so the "Front-end" profile is loaded first.
2 weeks ago
#113766
2 weeks ago
#113787
Which of the RSForm forms on your site have WYSIWYG enabled?
2 weeks ago
#113788
it's form 51
you can see it front-end here (it's a form ITM) : https://waterproofingpilot.com/index.php/0-wp-academy-front/06-blogs-landing/wpqc-explained.html
https://drive.google.com/file/d/11VVxTX2F5V866KzebLjz8_mwq1Qj8uTO/view?usp=share_link
2 weeks ago
#113789
the field
2 weeks ago
#113790
one week ago
#113796
Ahhh - so it is a matter of access levels, and ordering the profiles. I'll keep that in mind,
JohnJuhl selected the reply #113790 as the answer for this post — 1 week ago
