#113765 JCE EDITOR DOESN'T LOAD WITH RSform PRO
Latest post by JohnJuhl on Tuesday, 23 May 2023 06:35 BST
JohnJuhl
Hi guys,
when I allow WYSIWYG editor in RSform PRO text area fields - the fields can't be accessed and JCE editor doesn't load.
(RSjoomla tells me to contact you, since TINY mce DOES work.)
kr.
John
Which of the RSForm forms on your site have WYSIWYG enabled?
JohnJuhl
it's form 51
you can see it front-end here (it's a form ITM) : https://waterproofingpilot.com/index.php/0-wp-academy-front/06-blogs-landing/wpqc-explained.html
https://drive.google.com/file/d/11VVxTX2F5V866KzebLjz8_mwq1Qj8uTO/view?usp=share_link
JohnJuhl
the field
The editor is displaying in the front-end in my tests.
In the Editor Profiles list, the "Front-end" editor was second in the list, with the "Default" profile above it, which was also configured to load in the front-end, so this was being selected instead of the "Front-end" profile.
I re-ordered the profiles so the "Front-end" profile is loaded first.
JohnJuhl
Ahhh - so it is a matter of access levels, and ordering the profiles. I'll keep that in mind,
