I'm running a Joomla 4 website with JCE pro and when I create links using the "Content" option by opening the specific category and then selecting the article I want to link to, it fills the field with the standard Joomla query string, but then Joomla's SEF URL rewriting creates a URL that goes to a 404. The article I'm linking to is in the Uncategorized category which doesn't have a menu item. This has always worked in the past, but suddenly is not. Is this an editor issue or a Joomla problem?
#114386 Links to Articles Not Working
Latest post by holdsworthdesign on Friday, 11 August 2023 16:39 BST
Wednesday, 09 August 2023 20:58 BST
holdsworthdesign
Thursday, 10 August 2023 11:29 BST
Does the link work if you create it with the Article button below the editor area?
Thursday, 10 August 2023 22:19 BST
holdsworthdesign
Hello. No, it appears that does not work either which leads me to believe it's a Joomla problem - which leaves my wondering where to go from here? Do you have any suggestions on what to look for?
Friday, 11 August 2023 09:30 BST
In Joomla 4 SEF urls are created with reference to the alias of the menu items the article is associated with, if the article is not assigned to a menu, then a SEF url cannot be created (the SEF url is not created from the article/category alias).
One solution is to a revert to a Joomla 3 style of SEF URLs. To do this go to Content -> Articles and click on the Options button, then on the Integration tab, and set the Remove IDs from URLs to No.
Another more complex solution, but one that guarantees full SEF urls, is to create a hidden menu and assign the articles to it. The menu would not show up in the site layout, but would create correct SEF urls for each article assigned to it.
holdsworthdesign
Oh, ok. I didn't know about this change in J4. Thank you so much for taking the time to help even though it was unrelated to your component. That's very generous.
Please wait
Your post is being submitted…
