#101695 Problems with JCE Editor Pro Updates
Latest post by Ryan on Monday, 18 November 2019 09:51 GMT
Nasho23
I have LCE Editor Pro in my Joomla 3.9.13. I have installed the Key for Updates, but the Uptates will not run - Cannot connect to Server (403) I have Cleared Cache and retried with no luck.
Can you please advise what might be wrong here.
Also; what are the Un Install Instructions for JCE Pro.
Which version of JCE Pro do you currently have installed?
Go to Extensions -> Manage -> Manage, click the Search Tools button, and select Package from the Select Type list.
Select JCE Pro Extension Package and click the Uninstall button.
