The security token did not match. The request was cancelled to prevent any security breach. Please try again.
#106247 Editor does not load under Gantry5
Latest post by Ryan on Tuesday, 05 January 2021 10:38 GMT
MrFollies
Hello,...
I am experiencing the same behaviour as mentioned in this post:
https://www.joomlacontenteditor.net/support/forum/97723
It seems to be related to something with the Gantry5 framework.
I was wondering if it's possible to determine which component/plugin is responsible for breaking JCE as I'd really like to use it.
MrFollies
Done,... I got no notification that the message was received ok...
If not, please let me know..
The issue here looks to be with the Editor Profile assignment. Check that the profile you are using for this is assigned to All Components in Editor Profiles -> Setup (A Users component assignment is not currently available).
MrFollies
Wow, that was it! Thanks so much.
I had created a new group and was *only* using that group for the test users.
But the group was not assigned in the 'default' editor profile.
Thanks!
MrFollies
I'll read up about the editor profiles. Not sure how to use them... And how one is chosen over the other (for example when is "Front End" selected over the "Default" profile?)
The order is important. Think of "Default" as the least specific, so this should be lower in the profiles list than other profiles that have more specific Area, Device, Component or User Group assignments.
See - https://www.joomlacontenteditor.net/support/documentation/profiles/profiles-ordering
