#107073 Problem with JCE Joomla xtd button where tere are more then 1 editor Jformfield in a Jform
Latest post by Ryan on Friday, 12 March 2021 10:03 GMT
roland_d_alsace
Hi Ryan.
With the JCE Joomla editors-xtd buttons when there are several editor fields in a form, the field name in param of editor-xtd plugin is always then name of the last edidor field.
(For exemple in a config.xml form of a component).
So when you want to add a plugin content tag in the 1st editor field by clic on his button, the tag is added on the last editor field.
When you deactive the JCE button, (and using then standard Joomla editor button at the back of each editor field of the form), there is no problem.
Regards.
I'm not seeing this in my tests. Which editor-xtd button is this happening with?
roland_d_alsace
Arg... i have made a long answer with code etc... this morning...
...and all is lost!
Certainly i don't validate the reply 🙁
Is this a custom button or one included with an installed extension?
