#107259 Using JCE in a module
Latest post by Ryan on Monday, 29 March 2021 16:47 BST
alanorr
I'm developing a module for 3.x and I'd like to include an editor in the front end.
I've tried:
jimport( 'joomla.html.editor' );
$editor =& JEditor::getInstance();
echo $editor->display("desc", "my text", "600", "400", "80", "15",1);
which shows the text area but no buttons. It throws a Uncaught ReferenceError: Joomla is not defined error.
Is it possible to use the editor in a module or will I need to use one of the other free JQuery editors instead.
thanks
You should be able to load the default Tinymce editor with the code you are using. Does it load if you set it as the default editor?
alanorr
HI I tried the tinymce but it didn't work. I'm using Joomla 3.9.25 with php 7.3.27 and mysql 5.5.68-MariaDB
https://joomla.stackexchange.com/questions/3840/how-to-add-a-wysiwyg-editor-to-my-module
