is there a way to set a background color for an article with jce editor? Or is it possible to set a background color or an image as a background in a block?
Thanks.
Tobias
A content editor for Joomla!®
Latest post by Ryan on Wednesday, 11 May 2022 10:50 BST
is there a way to set a background color for an article with jce editor?You could probably do this by wrapping all the content in a div tag with a special class attribute that styles the div (best done in the Code editor), eg:
<div class="content-bg-1">
Your content...
</div>
then add the class to your template stylesheet, eg:
.content-bg-1 {
background-color: #eee;
but how effective this is will depend on how your template lays out the article content.
Or is it possible to set a background color or an image as a background in a block?Assuming you mean a column created using the Columns tool, again the best way is to use a css style in your template stylesheet, eg:
.content-bg-1 {
and then to select and apply this to the Columns using the Classes list in the Columns dialog, which I have just added in JCE Pro 2.9.21 Beta - https://www.joomlacontenteditor.net/downloads/editor/pro/development Ryan Demmer
Your post is being submitted…
