#116210 problems to save
Latest post by Ryan on Tuesday, 20 February 2024 11:01 GMT
beluqua
Hello
I have the problem that if I have currently written a post with the JCE and later reopen it and change something in it, the changes are not saved and are overwritten by the old data. I used another editor and this problem doesn't occur there. Could you please help me at short notice?
Thank you!
Best regards
What extension are you creating / saving the content in?
Do you have the latest version of Joomla, JCE Pro and this extension installed?
beluqua
I use the jce. We have already installed all current versions of Joomla 4 and jce.
What are you writing the post in? The Joomla Article Manager, or some other extension?
beluqua
I Write in the joomla articel Manager.
beluqua
In version 2.9.58 the update of a post is still possible.
This error only occurs in version 2.9.60.
I"m not seeing an issue on your site. If you look at the "test" article o the site you have sent the login for, I have modified and saved the article, with the modifications still intact.
