I am using JCE editor as my default and if I tap on the spacebar twice, a space symbol appears in the code. Which is fine, but it also appears on the text box in my JCalPro calendar. I asked Joomlashack to look into it, and they are saying it is your editor that is causing the problem, and that I need to go into the code and manually remove any spaces symbols. This is
I just tried the tinyMCE editor and the extra spaces symbols do not appear in the box that pops up when you mouse over an event title in the calendar view.
Go to:
February 2021 Calendar and mouse over the February 22 event for Grand Jury meeting. The
appears scattered in the text. Click on the title, and you are taken to the full event page for the Grand Jury meeting. The extra space symbols are not there.
So I am wondering if this is a JCE editor issue or a JCalPro issue. I switched to the TinyMCE editor, typed in extra spaces, and the issue was gone.
I have Validate Code turned on, and Keep Nonbreaking Spaces turned on. Could that affect the text the reader of the site would see?
Pat Vanden Bosche
