#111537 Insert Image not work by Text-Filter
Latest post by matrix on Thursday, 28 July 2022 20:02 BST
matrix
Hi
When a Cusomer insert an image, in the article will not insert the image - but any code (see picture).
When i change in the profile - textfilter to "no filtering", then it works.
How is the best config in backend on textfilter that it works with images and it's the best for customer there only work's with text and pictures. but great security for all other things?
Default Blacklist should be fine for most users.
matrix
Hi Ryan
Yes - this is the config that i have, when the problem with save -> then only code is saved in the article (my printscreen).
before any versions, this was no problem for the customer. but with actual version, the image will not insert by saving the article. only the code in the printscreen.
i have no chance with the Default Blacklist config. then, on save the article, the image will not saved only the code in my posted image.
This looks like something else is filtering or processing the content on save. If everything is working with the Super User account, then it is not the editor causing the issue.
Is this content being created or edited in the Joomla Article Manager?
matrix
Hi Ryan
Same problem, when i set "Default Blacklist" by Superadmin.
Yes, it is in the normal Joomla Article Manager.
I'm not able to reproduce any issue on your site.
I created a "Test Article" with an image and link, but if I set the Text Filters for the Super User group to Default Forbidden List and save, the content remains intact.
matrix
OK - strange!
But i have found "the problem" - when i made this:
i insert a image in a div (made with jce - 3 div side by side. i give the image this configuration (see printscreen ps1.jpg). then i save the article and i have only code in the 3 divs (see printscreen ps2.jpg).
And: i mean, this bug is only, when the image name have umlauts (ä/ö/ü etc). When i made this with a image that have not umlauts in the name, then it work's (see printscreen ps3.jpg).
I mean, it's a problem with handling umlauts in the filename from image.
Ok I can see this now. This looks like a bug in the Joomla Text Filter.
Can confirm the same thing happens with "No Editor"
matrix
OK - can i post this anywhere for Joomla? - or you made this?
