Then the fields for mousein and mouseout are displayed as empty,
More logical will be, that the mouseout-field should preloaded with the path/filename of der selected pic.
The mousein-field then must be selected by the user itself.
2. When trying to remove a rollover-event, it doesn't work.#
When clearing the mouseout/mousein fields by hand and then update the pic, nothing happens. The code isn't deleted, as you can see in the code-tab.
Only after removing the code the rollover is away.
May be it's a good idea, to implement a X-button to clear the fields by mouse.
