Hi, I have just migrated a site to Joomla 4 and working on setting up the front end editor. This site uses JCE media popups via a link to display another article in a popup window.
I wasn't sure if it would be possible to edit the articles that are displayed in this way in the front end. It did however initially seem possible in that there is an Edit button, and it opens the article correctly for editing. However if I try to save it or cancel it the editor doesn't exit correctly. I've attached a screenshot of the page rendered after hitting Cancel. The url that it generates is:
https://www.simstravel.co.uk/jom4/coach-excursions?view=article&id=6:newcastle-or-metro-centre&catid=8:excursions&tmpl=component
These are set up on the following page:
I can forward login if required.
Jennie
Jennie
