#114559 not editor
Latest post by callara on Monday, 04 September 2023 13:01 BST
callara
Hello, I am using joomla 4.3.4 version and php 8.1.22 - but I cannot make your plugin work, is it compatible with latest version ?
I had installed the free version on previous joomla version, and it was working, since I updated the new version, I cannot see your editor. I tried to installed the pro version and it's still the same, no editor.
Please help
Your screenshot is showing the core "CodeMirror" editor.
Check that you have set JCE as the default editor in the Joomla Global Configuration. Also check that the editor assigned to the user in Users -> Manage -> Basic Settings is either "JCE" or "Use Default".
callara
it is set to jce !
callara
sorry, you are right, I had not changed it by users, but by global configuration, site, default editor. Now I changed it for the user and it worked !
tks for your help
