For me, the "search and replace" in Code View feature is a little bit strange - or to different from "common behaviour". A attach a GIF which shows what I mean.
a) I press "search" - it finds string 1. I press "replace" - it replaces the string on occurrence 2.
b) I press "replace / replace / replace .." - it always replaces the next occurrence of the string without highlighting and changing the cursorposition before! replacing
c) I press "replace all" - there is no message like "Done" or "Done. 5 strings replaced" or "String not found"
Is this intended?
Edit:
I think it would be very helpful (state of the art) when the input-fields for search and replace would show and offer the last used string - at least only the last one, better some strings more ....
Is this intended?
Edit:
