JCE 2.9.52-beta3 does not solve the problem
#115060 Systeem - JCE MediaBox 2.1.5 is NOT Joomla 5 compatible!
Latest post by Ryan on Tuesday, 14 November 2023 09:28 GMT
Thursday, 26 October 2023 16:20 BST
Henk Haak
After upgrade to Joomla 5, Systeem - JCE MediaBox 2.1.5 is responsible that the site does not come life. After installing Systeem - JCE MediaBox 2.1.3, the site, running at Joomla 5, is up and running. At this moment I am not certain if all functions are oke.
Thursday, 26 October 2023 16:43 BST
JCE MediaBox 2.1.5 works as expected in my tests on a Joomla 5 site.
A new version will be released next week.
Thursday, 26 October 2023 18:09 BST
Henk Haak
I just tried it again. I installed JCE MediaBox 2.1.5 and the site does not start. If I is disable the MediaBox plugin in Extensions -> Plugins, then the site starts, but of course the Mediabox functions don't work. Hereafter I re-installed JCE MediaBox 2.1.3 and the site is up and running again including the Mediabox functions .
I do not know the difference between my Joomla 5 and yours, but that my site does not come to life is sure.
Friday, 27 October 2023 10:43 BST
Clean install of Joomla 5 with JCE MediaBox 2.1.5 installed using Install from Web. Enabled JCE MediaBox in Extensions -> Plugins after install with no issues.
I would suggest you uninstall JCE MediaBox before installing a new version.
Edited by Ryan on 2023-10-27 10:44 BST
Tuesday, 14 November 2023 08:51 GMT
IDD-NET.DE
When uninstalling, are the settings gone after reinstall it after Joomla 5 update or do I need to set the Popup for hundreds of images again?
Installling, updating or uninstalling does not alter existing popup links in articles.
Please wait
Your post is being submitted…
