Solution find??
I have installed Mediabox 2.1.5 over 2.1.7. With 2.1.5 the Popup will work.
Then i have installed 2.1.7 - and the Popup will now work under J5.0.2.
Strange...
Hi
I have updated two sites to J 5.0.2
By this sites, the Popup will not work correctly.
When i click on a image (with Popup-Function), the image (for example) will open in the
same windows from website (no Popup). The image will show as image and not as
Popup with Button to close etc.
I can only click "return" in the browser to come back to website.
Thank you for your help!
See on wellboys.ch (Frontsite) - under Frontsite-Article "Visitenkarte". Here are two images with Popup-function that will not work so.
Under old Website J 4.4.2 the same Popup will work (see: https://wellboys.ch/cms_j4_20231216
Strange...
Hi
