#116540 issue setting a link on font awesome icon
Latest post by Ryan on Thursday, 28 March 2024 13:18 GMT
zetcom
First of all, thank you for adding the fontawesome plugin! Great, I love it! :D
Inserting fontawesome icons works fine. However, there is a problem with adding links to those icons.
Unfortunately, adding a link is not possible in the "editor view" of JCE.
You can set a link in the "code view" and it will remain when you save - but only if the article is saved from the "code view".
If you switch to the editor view and click save, JCE removes the link from the icon.
It looks like the code is being cleaned up and <a> tags are not allowed on <span> tags.
Is there a setting somewhere that prevents this?
In order to improve selection of icons, and cursor placement around them, I changed from using a <span> tag for the icons in the editor to an anchor tag <a>. The <a> tag would then be converted to a <span> when the content was saved.
This works really well, except I forgot about the possibility of creating a link on an icon, and nested <a> tags are not supported!
I'm having another look at this, and will probably revert to using <span> tags in all instances. I'll keep you posted.
